Cutting “keys” in my miter joint
I bought the book Basic Box Making and then the DVD. Doug Stowe goes into great detail about making a box and dressing it up. However, when he cuts keys in his joints w/ a jig and they look great. He does not mention what kind a table saw blade he is using.
The blade I have is an “ATB” tooth design and leaves a V shape grove. A dato blade is 1/4 and too thick.
Ans suggestions on a blade and tooth that is flat and not crazy expensive?
Freud has rip blades with flat tops. LM72 is full-kerf. LU87 is thin-kerf.
Thanks, for all the good thoughts. I will get the blade (next pay day) and try the file on the box I am working on.
Thanks again!
Ed
Forrest makes a Woodworker II (special grind) 40T blade that will cut a flat 1/8" kerf. Like all Forrest blades, it is pricy (> $100). I bought one at Woodcraft.
Mr1911
If you're doing one box at a time, cut by hand in the time it takes to set up the T-saw.
I’ll assume by your name you are a fan of Mr. Browning’s greatest creation??
I used my Forrest Wood Worker II saw blade, (best on the market IMO), and use a small file to flatten the bottom of the kerf so the key sits flat.
Stupid old man here..
If the sticks are wide enough..
Use the blade you have! Cut/Plane/Sand the splines to match!
ditto the LM72, that's what I use along with a jig to hold the piece at a 45 to the table.
Bruce S.
