I’d like to take a square piece of stock,set it on it’s edge, and cut a cove in it so that the opposite edge fits into a corner. There has to be a jig or a way to cut a V groove in a board to hold it as it passes across the saw. Maybe if I cut one edge off first.
4Runner
Hey 4runner.
I'm having trouble visualizing exactly what you're trying to do. Answer my questions below and I'll have a reply for you:
"I'd like to take a square piece of stock,set it on it's edge"
what are the dimensions of the piece (thickness by width by length) and which edge is it set on?
"cut a cove in it so that the opposite edge fits into a corner."
Where is the cove being cut, is it a radius cove and how will that allow the opposite edge to fit in a corner?
Sorry for being so picky but sometimes writing a question makes it sound more complicated than it really is.
Matt Berger
Fine Woodworking
I would like to put a cove in a sq. piece of stock sitting like a diamond, on the left or right edge. The dimensions are 1 1/2x 1 1/2, so that the opposit corner will fit in the 90 degree created by the over hang and the rail.
Good to hear from you.
4runner
p.s.
How can I send you a sketch?
Hi 4runner. It makes sense now. The shape you describe is actually a standard corner molding that you can purchase at Home Depot or the like. However, it doesn't come in the dimensions you want and probably is only available in a softwood.
I'm not sure I have an answer for how to produce it. Ideally, I'd do this on a router table with a quarter-round bit. Basically start with a wide peice of stock that's 1-1/2 in. thick (maybe 4 in. wide), run it past the bit to create the cove profile on one edge, then rip the molding off at 1-1/2 in. wide on the tablesaw. You should end up with a piece that has to sides measuring 1-1/2 in. and a cove opposite the 90 degree corner.
The catch is that I'm not sure you'll find a quarter-round bit large enough to match the dimensions you're after. Do you know anyone with a shaper? If so, I'd use the same procedure as described above using an adequately sized quarter-round shaper bit.
If you want to try the tablesaw cove cutting technique, I'd start with a wide board, cut your cove, and then rip the board at 45 degrees on both sides to cut away the waste. Can you picture that?
- Matt
P.S. to attach a sketch, create one in a simple drawing program (you should have Paint installed on your PC by default) or take a digital photo of a hand-drawn sketch, save it as a file on your desktop, then upload the file using the "Attach Files" option when you compose your message.
Thanks a lot! I like the last one where rip off the part I need a t a 45.
Thanks again.
