Cutting out an ellipse with a router…
I want to build an oval coffee table, which is essentially an ellipse when it comes to geometric shapes. I have recently used a circle jig for cutting out a circular table top and I loved the way I was able to cut out a perfect circle rather than trying to cut it out using a bandsaw or a jigsaw for that matter. My question is, is there a jig that I can use with a router that will allow me to cut out an ellipse given that I know the semi-major axis and semi-minor axes? I have searched the archives and haven’t found anything yet. ANy help would be appreciated.
Buzzsaw
“Don’t ask yourself what the world needs. Ask yourself what makes you come alive, and go do that, because what the world needs is people who have come alive.” Gil Bailie
You could make yourself something like this:
http://www.trendmachinery.co.uk/ellipsejigs/#ellipse
For marking one out, two brads and a loop of string will do it. Maybe a variation of this will give you an idea for a router jig. Draw the x and y axis lines; tap two brads an equal distance from the center on the long diameter; make a loop of string long enough so that when circling both brads and pulled tight with your pencil, the pencil touches one of teh farthest two points from the center; move the pencil and the string will make it draw an elipse - the shape of the ellipse will be dictated by the placement of the brads (the farther apart, the narrower, and the closer, the rounder).
Thank you. I will check out this link...Regards,
Buzzsaw
Link update
The link in comment by @Samson no longer works. The new link, which shows the jig in action, is http://www.trend-uk.com/en/US/product/U*ELLIPSEJ_A/3/16/_ellipse_jig_type_a.html
Hi Buzzsaw,
Hi Buzzsaw,
You might also take a look at - "The Victorian Cabinet-Maker's Assistant" page lii (roman numerals) - available as a Dover reprint edition
In the section labeled "second method " is described a method for drawing an ellipse with an apparatus working on the same principle as the router jig Samson refers to (the web link).
The operation is described in detail and may be of assistance in designing and using a router ellipse jig.
Darrell
Thanks for the info. I will check it out...Regards,
Buzzsaw
There are jigs that allow you to select the major and minor axis but the ones I have seen give you a pencil drawing not a router holding device.Unfortunately I gave a jig I made using aluminum tracks joined in the center making a large plus sign.Aluminum pieces sliding in the tracks were connected by a bar holding a Dremmel.Dont recall the details using it but it left some areas un cut.I suggest you go to someone with an CNC machine
Odds are good he finished his table about 15 years ago.
MJ, We all take waaay longer to complete some things in the shop than we should. He probably just got enough Benjamins to buy his Festool router. It will get done soon. Hopefully. BTW, good catch.
I believe Paul of The Shop may have a time machine, in which he goes back to "the good old days" of The Knotters, many of whom are probably now dead as wooden nails.
Perhaps in the future (if we humans have a future other than that of a few Morlocks scrabbling about in the radioactive dust) folk perusing the FWW website will dig us up, with our mouldy old posts that never mention anything about how to program the robot to make a new chair instead of the tea.
