Cutting short boards with chain saw
Does anybody have experience cutting short…….12 to 18 inches……..boards with a chain saw? I don’t have a band saw. Any thoughts would be appreciated.
All sorts of exciting possibilities come to mind. A few more details on what you're trying to accomplish would be helpful.
Pete
I know the boards won't be large. I've cut several before out of cypress, pecan, oak, hackberry, and mesquite. I don't have a joiner and use my DeWalt DW746 table saw and DeWalt 13" thickness planer to get the boards to the size I want them. I'm using a Poulan 18" chain saw. I lay the log on the ground and use several stakes to stabilize it while sawing. Normally I can run the pieces through my planer making 1/32" passes due to the roughness. I didn't feel safe running the pecan through my planer due to the rough cut and had to take them to a local cabinet shop. I usually end up with boards 1 to 2 inches thick. Haven't planed any to the final dimensions I'm looking for.....3/8 to 1/2" as the wood is still drying...did end coat with wax. I'm thinking a better jig would be helpful and not result in as much waste. Eventually I'd like to use the boards for small boxes and keys for mitered joints......
I do the same thing that you are doing, but I add the fact that I use sawhorses to get it up off the ground and I use my Stanley 5 1/2 C plane with a blade that can be quickly resharpened (sharpened at a straight 30 degree bevel and well-predictable in sharpening characteristics) to get the billets roughly flat. I use a a bar of that "gulf wax" available where canning supplies are sold on the bottom of the plane to make it work faster and smoother.
I am making a lot of stuff from dogwood I have from hurricane Ivan in 2004 now, and laying in a stock of project wood including dogwood, pecan, sycamore, and some unidentified as of yet hardwoods from that damn b**** Katrina's bounty.
I have two chainsaws now, one with an 18 inch bar and one with a 20 inch bar. Both are well-sharpened and tuned but I'm going to order a ripping chain blade off the internet for the 20" one.
Take care, Ed
Your local power equipment shop can grind you a rip chain also.
Pete
AHHHH!!!!
Bubba building!! :)))))) LOL!!!
Works great building deer blinds along with a good screw gun and extra batteries.
Been there, got the Tshirt!!!
Might Try Northern tools they have different milli attachments.
http://www.northerntool.com/webapp/wcs/stores/servlet/CatDsp?storeId=6970&N=100+85630&Ne=2
MK
Edited 11/8/2005 9:24 am by MiKro
.....I have a link from VATom at BT, he and I were discussing similar thoughts.........
http://www.baileys-online.com/
look for the Beam Machine ........on the Sawmills page of the on-line catalog....you might have to modify your chain to use it however, which would require resharpening to reduce the anti-kickback feature and allow a more aggressive cut......
here is the thingy......"
With the proper precautions, that are required with any chainsaw work, you can do this safely and fairly efficiently, though you will waste a lot more wood than cutting with a bandsaw.
Go to a shop that sells and services chainsaws and get a chain or two ground for rip cutting, they'll work much better than a standard chain which has a tooth geometry meant for crosscutting. Removing the bark, before you saw, will considerably extend the life of the chain between sharpenings.
Seal the ends of the boards with paint or a specialty sealer to prevent end checking while the stock seasons.
John W.
