New to using a table saw fixture on the table saw (Jet fixture ) .What is the correct sequence of cuts and do you cut the cheeks and shoulders there also.
Blainel,
Generally, the shoulders are cut first, then the cheeks. If you scroll down the left side of your screen you will find the Search function at the bottom. Type in tablesaw tenons and you should get a bunch of results.
Welcome to Knots!
-Nazard
Many thanks for the tip on where to look, I'm also new to this forum, I found many articles and tried some today. Thanks. Blainel
