I have a Delta Platinum Edition Contractor’s Saw wired for running on 220VAC.
I’m planning on buying a stacked Dado blade set and would like some feedback as to which brands are good performers and good value. Also, is there any reason an 8″ blade wouldn’t work satisfactorily on this saw (vs. 6″)?
I have the Delta Platinum Contractors. I use the the delta 8" stacked dado. No probs. Does everything I want it to. But I did see my bud use his systematic once WOW it was nice. I going to get my delta sharpened, my man manny, and see what happens. A good sharpening guy can do wonders.
Darkworksite4: When the job is to small for everyone else, Its just about right for me"
Ron:
Thanks for the info. I'll look at Systematic -as well as delta.
Jim
I bought the Freud 8" SD208 for about $90 and have been happy with it....
I'm a fan of the Freud dado sets (specifically the Safety Dado, which is the one I have experience with). They've gotten good customer reviews, and they're come at a good (reasonable) price.
Dave:
Thanks. My inclination was to go with the 8" blade. I don't intend to overwork it however.
Jim
I bought the Delta 8" set and a set of magnetic shims. The bottom of the dado requires cleanup if you're a perfectionist. I've run it full width on my Jet Contractors saw and only had a power problem once when cutting some gun stock walnut. But then my Forrest II wood wrecker had a tough time with it also. Most of the time its in on my RAS.. I've been doing a ton of Melamine and MDF cabinet work and for this it works great. I've never had it sharpened but suspect it should be.
By the way, if you are expecting a super clean dado from a dado set, dont. Use a router instead.
Steve - in Northern California
I have both a 6" (Delta) and an 8" (Freud) dado set that I use in my Unisaw. I had the 6" set first, and needed the 8" for a special application. I still use the 6" most of the time, it seems to cut smoother. I need the 8" for finger joints in 5/4 (or thicker) lumber. They both cut the same thickness dado, but the 8" gives greater depth.
I have the 6" CMT and am happy with it. I would have gotten the 8" but it wasn't in stock and I needed it that day. There's been a few times the 8" would have come in handy where I could have used a sled but the blade wouldn't reach. Get the 8". Besides the 4 tooth 1/8" chippers CMT includes a 1/16" and a 3/32" chipper, which makes it easy to match plywood thickness. The bottoms of the dados are pretty smooth, but not perfect.John O'Connell - JKO Handcrafted Woodworking
I have the Jesada Joint Master 8" set. I find it great and it includes colored shims and a chart to help set the most common widths quickly.
Gee Dave, I'm glad I didn't know that when I put an 8" dado on my Delta Contractor Saw 10-12 years ago. Seriously, so far it has never bogged down in anything I have cut, cherry, oak, maple, etc.
Even cutting to pretty much the full depth has been no problem.
Forrest IMHO is the best.
JIm
