After some twenty plus years, I think it time to replace my 6″ steel dado set. Anybody care to make suggestions? I hear they are available with carbide tips. Wow
joe it depends on how much you want to spend. I went cheap and bought the delta 8" set for about 89 bucks. It works great for everything I need it for. But my pal shady has a systematic and its the bomb.
Darkworks: Its all 'bout da squilla
I agree with the squillaman, I have the 8" Delta and it has been good, and doesn't break the bank. Some folks will quibble about the cut quality but I have had good results so far(if you need glass smooth cuts use a router). Will post pics if interested.
Mark
If a 6" dado does the work you need, I'd stick with that. You can get a higher quality dado for the money you spend, and not be flinging around a bunch of weight that's not needed.
I use the Freud Safety Dado (6") and have found it to be a very nice tool. Cuts clean, fits the arbor better than a glove, and reasonably priced. The 8" is $85 at Northwest Power Tools. Haven't found the 6" on-line, but it's out there somewhere. Their other models are "Super Dado" and "Professional Dado." The Super Dado runs around $150, and is better in ply and melamine than the others (I think; haven't used it).
I just bought the Forrest Dado King. An upgrade from my 89.00 Delta. A big jump in price AND quality of cut. If you want the best check it out at 3D Saw Blades. They had it for 50.00 less than direct from Forrest.
Systimatic 8" with the higher grade chippers. Spend money now, get buried with it. Doesn't even chip cross cutting cabinet ply. Ya can't beat that.
"The child is grown / The dream is gone / And I have become / Comfortably numb " lyrics by Roger Waters
frued Blade have been around for awhile but just recently i was turned back on to them. The are carbide tipped and you can get the Dado blades in either 6 or 10 inches. The price is great and the claim that there is will be no vibration in the blade. I personally just bought there 10 inch teflon coated blade for my table saw. It touts its ability to cut through double sided melamines with out a scoring blade. WOW it really worked. Clean and precise.
Joe, I also started with the Delta set, and then upgraded to the Forrest set. I've never tried another top-of-the-line dado set, but I can't see how any could be that much better than the Forrest. Also, no comparison between the Delta and the Forrest. You get what you pay for.
Been using a Freud 8" Super Dado for ~4 years. No complaints. Used it in a wide variety of materials (pretty much whatever you can think of) and it's worked very well. There maybe better out there, or others that are better value however. Just my 2 cents.
Jon
