I am trying to find a good tool to make the dado in drawer’s for the bottoms. Is there an inexpensive plane out there to buy to perform this job? I seen Veritas’s new plow plane and like it a lot, but did not want to spend $200 for new plow plane. I know I could use a router table easily, but I would rather do it by hand. Any suggestions for me?
Thank-you all again….
There are many vintage plow/groove planes that work fine and can be had in user shape for $100 or less. For example, I love my Stanley 248A for things like cutting grooves like drawer bottoms. Check the old tool dealers and/or eBay. Perhaps you can find a decent user plow plane from Record or Stanley - there are plenty of models other than the 248.
Here's a nice one. It may be too clean, and therefore collector bait ($$$$), but maybe not:
http://cgi.ebay.com/VINTAGE-STANLEY-NO-248-WOOD-PLANE-TOOL-5-BLADES-EX-C-NR_W0QQitemZ140160267112QQihZ004QQcategoryZ13874QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
W,
I found a nice new Mujinfang plough plane at Tilgear, a British tool seller. But Mujinfang are Chinese and sell internationally.
The plane is wooden (hardwood) with a steel skate and can be got with 5 blades from 1/8" to 3/8";or with just a single 1/4" blade. The blades are surprisingly sharp and stay that way.
I won't pretend that the plane is super-duper but it is not rubbish and can be made to work well. I paid a mere £25 ($50) for mine, with the 5 blades. It was £15 with a single blade......
Record 43 or 44. Decent quality can be had for less than half of the new LV.
Technically, you do not plough a dado for a drawer since a dado runs across the grain. What you require for a drawer is a groove that runs with the grain.
There are two types of grooves that may be used. The more common one, typically used when the groove is hidden by a half blind dovetailed front, is a through groove. This is easily cut with a plough plane.
At the rear is a Stanley #45. Front left to right is a Rapier #043, Record #044, and a Stanley #46.
(The Stanley #46 is the plane of choice for a cross grained dado).
An alternative is a dedicated drawer plough. This one cuts a 1/4" groove at a fixed distance from the edge:
The second groove for a drawer is a stopped groove, which must be hidden inside a drawer with through dovetails.
This may be cut with a groove that is first chiselled out then flattened with a router plane:
