I always understood never to use the rip fence when cross cutting on a table saw. However, many times i’ve seen pros on TV use the rip fence when cutting dados or rabbits. Is it safe to do that?
That is a perfectly safe and accepted technique because there is no stock being trapped between blade and fence.
You are correct when you say you should not use the fence (a a stop) when crosscutting. That is because the "drop" would be trapped between the fence and the blade and it will kick back (the first time I did it before I knew any better it hit me right between the eyes!!)
When cutting with a dado blade there is no "drop" to be trapped- you are simply cutting sawdust- so no problem' That is how I usually make tenons- cutting with the dado blade and the length of the tenon is determined by the fence.
Hope that clears things up for you.
Bob Van Dyke
Thank you. That confirms what I thought and observed but it had never been specifically stated.
