Dado set missing cutters and flanges
I have a Makita 2708 table saw and a Makita 6 inch dado set for it. However, the dado set is missing the inner cutters and flanges. Can these be purchased separately? Do I need Makita cutters, or can I use other brands?
As long as they are drilled for the correct arbor size any dado set is compatible but the number of 6" set will be limited.
I am not quite sure what you mean by flanges and I'm assuming inner cutters are the chippers but it doesn't sound like you have anything more than a couple of 6" saw blades. Buying a complete new set probably is your only option.
I wouldn't mix and match from different dado sets. They could be very dangerous. Don't mess around -- buy a new set.
