How deep should dados be for a 3/4 birch plywood shelving. I was going to make them 1/3 of the width deep… anything wrong with that?
Fred Palmer
Fred Palmer
As long as the shelves are solidly seated in the dados, and can't pull out, then a depth of 1/8 to 3/16 is sufficient and it leaves the uprights stronger and less likely to show small kinks at the dado locations.
John W.
As you pointed to, the rule of thumb is no deeper than 1/3 of the thickness of the material. Less is okay, but more makes a weaker joint.
I follow Norm's rule of thumb.. 1/4".. even if you assemble it and forget the glue.. the shelf is wedged in there a total of 1/2".
It ain't comin' out.
