Any suggestions on a wood to use that will finish black. I’d like a strong dark contrast to a Cherry wood project?
Walnut finishes quite dark, but not quite black, and it's easy to work with. Some of the truly black woods, like ebony, are very expensive.
Walnut's good, so is Wenge, which is very dark, almost black.
Namaste,
Gary
http://gwwoodworking.com/
Wenge.... Thank you
Dave
Not sure of the proper name, but the tropical hardwood I've seen sold as tropical walnut or peruvian walnut finishes much darker then juglens nigra.
Paul
I've never worked with Peruvian walnut, so I don't know the color. However, here's a cherry countertop with a black walnut feature strip in a Swiss chalet in Kirkwood, CA.
http://gwwoodworking.com/rook/images/rook1_jpg.jpg
The photo isn't that good, but the walnut stands out against the cherry. There're a number of species in this project, including VG Fir doors and walnut, both of which were resawn from hundred year old timbers, the walnut from 2 1/2-in-thick Taylor Winery, bergundy vat staves. Namaste,
Gary
ebonized maple..is good.
What is that? Is it blacker than Wenge?
Dave
Ebonizing is a finishing technique, and maple is a common wood to use it with. If you Google on "ebonizing finish" you'll get lots of hits.
Fuhr makes an ebony stain. You could probably get some input on technique at Jeff's forum (at the site in the "ebony stain" link).forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanx for takin the time to post those links..way cool.
Go Stab yourself Ya Putz! Ya think I Parked here?
Thank you girl of forest.
Dave
as black as you want and a helluva lot cheaper than any exotic. DYE maple with black dye or ink, or lampblack, or a sharpie marker..you can ebonize cherry for that matter.
So that is what ebonizing us. Is it difficult using lampblack? What is a good source?
Dave
A good source..I use a base concentrate that is not available for retail sales, it is a waterbased formulation from my days making stains, with Michael Dresdner.
Artist oil paint would be a good start..search the archives here..it works sometimes.
India ink, carbon black, and sharpie markers DO work.
some one will be along with THE answer.
Over time, walnut will lighten considerably and cherry will darken, minimising the contrast. Have you considered purpleheart?
Hi Rob,
I've used purple heart as a contrast with maple, have you used it w/ cherry or walnut?
I've used it with walnut and honduras mahogany, but not in massive amounts. The table tops I make have a large center field of solid wood, which is then banded with 5/16" of purpleheart and 1/2" of the center wood on the outside. I made a wild cuttingboard from p'heart and yellowheart a few yrs. back. Waxed and buffed to a high shine, it hurt to look at it.
The arguement against ebonizing maple ( or poplar) and for walnut is that a ding in ebonized maple will show light wood!
If you want a true black, ebonizing walnut is the best that I've ever done. You can use pretty much any wood, but using a wood that is already dark will make for less coats before the wood is truly black...
I use a water-based dye (transtint) from Jeff Jewitt.
http://www.homesteadfinishing.com/htdocs/TransTint.htm
Thank you Brian. I like the samples they have on their website.
Dave
I also like to ebonize walnut. I use an iron acetate solution made by soaking steel wool in vinegar. It reacts with the tannins in walnut to produce a really ugly gray that turns beautiful jet black when finished. If you search the archieves, I and others have posted about ebonizing wood.
hi Dave Im a proffesional furnituremaker in Ma ...I use Walnut a lot with cherry..if its a top sometimes its noice to leave the sapwood in for an interesting texture
Thanks for the comments of the use of walnut w/ cherry. Do you stain differently so as to get a greater contrast?
Dave
Hi Dave; I built a display case for my wooden toys out of carob wood, cream colored with lots of reds, and wanted a dark contrasting wood too. I tried walnut, because it works great, and after it was all sanded I applied a couple coats of black water based dye. It looks like ebony and worded even better, and a lot cheaper. It is had to find a 5' long piece of ebony, but easy to find walnut. Roger
Is that an ink dye, or what?
Dave
