I am new here and not really a woodworker, so to speak. But I have a question.
I am completing our house. The kitchen cabinets my wife liked have a knotty pine door with a natural finish (I assume it is lacquer). But now that the cabinets are installed she would like the doors darker to match the other woodwork in the room. The other wood is finished is more amber (like Minwax ipswitch pine) on pine.
Does anyone have any suggestions? Can I spray a topcoat on the doors to enhance the color? Would an amber shellac work?
...she would like the doors darker ...
howz about a good grease fire? - otta do it - <all right, just a joke> - shellac will stick, try it on a scrap and see if it gives you the look you want - - I bet someone here will offer another good suggestion or two -
Minwax, and probably others, make a product that combines stain and polyurethane. This is probably your most durable option. Apply directly over cabinets.
First, the finish on the doors probably is lacquer, and will probably amber a lot on its own over the next year or so.
Second, the easiest way to slightly alter the color of a lacquer finish is with a toner. The proper definition of a toner is color in a highly reduced topcoat. Get some TransTint or other dye concentrate (easiest), dilute some lacquer with about 5 parts thinner to one part lacquer, add just enough color so you can barely see where you are applying it, and apply multiple thin coats until you have the color you want. Go slow and don't pile the material on, and shoot your details before you hit the flats.
Topcoat with clear lacquer.
This is easier to do than to describe. It's standard procedure in furniture factories and in finish matching. It doesn't work very well for radical color changes, but it's good do darken a color a little bit, or to adjust red / green balance.
Michael R.
