I am planning to make a toy chest and finish it with milk paint. I’d like to use baltic birch plywood or possibly MDF. Is it possible to cut reliable dovetail joints in these materials?
roberto, at los angeles
roberto,
at los angeles trade tech we had an old dodds dovetailing machine and it was often used to cut dt into 1/2" plywood drawer sides and fronts. the result was usually quite a bit of tear-out at the back of most cuts, but it did a decent enough job.
if you are thinking about hand-cut, then the cross-grain in the plywood, may be difficult to chisel out. a good dovetail jig, sharp bits and perhaps a backer board to minimize tear-out, ought to work ok.
by the way, the last choice for an oft-used toy chest would be mdf. the stuff would disintegrate in no time and, besides, it tends to off-gas some pretty nasty chemicals that you may not want around the children
eef
Joining MDF/PLY
I have to agree with Eef on this. The best option I find for plywood joints is either to cut box joints on the table saw with a box joint blade (Freud make a great one) or just use biscuits. Your going to paint it anyway so the option is really just a matter of what is easy for you with your equipment and skills.
Robert
material choices
I'd use Poplar instead. Although Baltic Birch ply is better than construction ply, it is still subject to tearout at the edges.
Plywood Is No Fun To Dovetail
You have gotten some good answers already, and basically what I would have recommended. Personally, dovetails only work well in solid wood, they can made in plywood but it is no fun, and in MDF it is a very weak joint.
dovetails in bb...
there are mny commercial suppliers of drawer comonents who can flog this , ergo there must be a way.....
what about Set-ups on the router table with zero clearance backers.
Either that or mac-tac "wrap the corner" stuck on dovetalils.
Save a bunch of work it would!!!!
Eric
