Being soft in the head I have agreed to re-finish a small desk top which was badly scratched, nothing special but useful. On removing the finish I find parts of the surface are about as hard as Balsa whilst the rest is a bit better but still too soft for my liking. I think it is Deal.
I have gently sanded, planes just about sink in, and applied shellac to stabilize the surface.
Has anyone experience of finishing this sort of surface please? My inclination is to top the shellac with Rustins Plastic Coating which, being an epoxy type, does have film strength, but is there any way of first treating the wood to resist damage?
Mufti in hope.
By "Deal" I think you mean White Pine. The late wood is a little harder than the early wood but not by much...
I've had good luck by sanding small fields with an oversixe block sander. It woorks well for small areas like a isde table or a coffee table. I slide a sanding belt over a sized piece of hard wood and go at it.
Sorry, I have not made myself clear. I have got it flat, but is there any good way of hardening the surface before finishing? I am considering using a product made for dry rot treatment.
Mufti
I have built a few small items, mostly boxes, out of Paulownia, which is as soft/light as Balsa. These were finished with Danish Oil since, as you identified, the surface needs strengthening. I found that this worked well enough.
Try a "wood conditioner"
I think minwax makes one that would be redilly available
"wood conditioner" is not much more than thinned shellac, and is for decreasing the liklihood of blotching when staining the wood.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
The stuff I am trying is Bonda Wood Hardener made by Bondaglass-Voss. It seems to be working but I will know more in 24 hours. Not shellac but Diphenylmethdisocyanate and Isomers. Well you knew that anyway.
I last used this stuff on a window sill and it outlasted the frame.
Wood hardener is quite different from wood conditioner, sure hope it works for ya!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I don't think anything can make wood "harder". It can put a coat/layer on it that makes it more abrasion resistant/"stronger"--just like adding a piece of veneer or such would just add a layer of "something".Gretchen
"I don't think anything can make wood 'harder'."
You can make wood harder and more stable by impregnating it with resins. It's done all the time. Mostly, though, it's an industrial scale process that requires high pressure and high temperature, not an at-home, do-it-yourself kind of thing. The hardeners that work the best are the ones that penetrate the most deeply. (I don't personally have a broad enough experience to recommend one brand over another.)
OK, fine. It CAN be done. YOu can't go to HOme Depot and get a "wood hardener". Of course,ANYthing is possible. I don't think this is what is being discussed HERE for a desk. GEEZ.Gretchen
I have had good results "hardening" soft porous wood with thin epoxy resin painted onto warmed wood to the point of refusal. WEST System 105 resin/206 slow hardener (thinner than the other hardeners) is what works best. If the piece is to be finished natural, then use 105/207 instead.Bill
Your right, I may have misstyped. The hardener that i've seen used is a lot like the cyanocrylate (crazy) glue. It soaks into pine pretty readily.
Please don't put plastic on it. Just finish it and tell the user to get a desk "blotter" to use on top. Is it an old piece?
I take your point, but with this product I have used it many times, with thinned coats and after burnishing it gives a non-plasticy and enduring finish. Not at all like Wests which I have just not got on with in outdoor situations.
No, this is a cheap modern bit of furniture but my sister-in-law thinks I can make it look better! Using a protecter is the best option.
Edited 9/15/2007 3:48 pm ET by mufti
Is it absolutely necessary to use that top? Would it be possible to laminate a thin layer of another kind over the soft species and make it more durable?
I apologise for the delay in replying, we have been on holiday.
I refitted the top today, the wood hardener worked perfectly and even gave a high gloss finish which I took back a bit with 1500 grade wet and dry, then a tad of wax to give a nice smell to fool folk.
