Delta 46-700 Lathe Bearing Replacement
I am having problems removing the spindle bearings. If anyone has successfully done this, I would appreciate a how-to description of the procedure. I have the spit rings removed on both ends of the spindle and re-clamped the belt pulley so as to allow the spindle assemble to slide forward. I can not seem to figure out how to separate the bearings from the shaft. Thanks for your advice….Mark
This post is archived.
