Delta 6” Jointer 37-195 Fence Stop Dimensions
I’m looking for someone who has the Delta 6” Jointer in their shop that could provide the dimensions of the Fence Stop (part # 1346736 item 101 on the part diagram). Somewhere in my shop I have misplaced it and may need to make another. It’s mostly the thickness I need as I can guess the rest. The bolt and washer are also missing but I believe it is a M8 x 1.25 x 16mm that binds in the threaded hole at a certain depth to allow the Stop to flip into and out of place. Can anyone verify this for me? I can’t seem to recall when these parts went missing.
Paul
I have a Grizzly G0452 which appears to be a clone of your Delta. You may be able to source the part from Grizzly.
The bolt has an unthreaded shoulder which is 0.375 diameter.
Mike,
Thanks so much for that detailed information. I’ll see if I can source those parts. When I try to screw a M8 bolt into mine it stops after a few revolutions. I’ll have to take a closer look at the threads to see if there is an issue there. My first time on the forum and the results were outstanding. I really appreciate the quick help!
Paul
You're very welcome.
Have you tried E-Replacement parts and Renovo.
Pretty sure that is an off-shore Delta but, your 8mm may be a 5/16 x 18 thread.
I had a 8mm bolt I just ran through the threads. I guess there was some thread locker in there causing the slight bind. I’ll order the parts from Grizzly. The (3) parts total $3.00 plus shipping - quite the bargain. Thanks again for all of the help.
Paul
