Delta Contractor saw out of alignment
![](https://secure.gravatar.com/avatar/a5658828d89e4dcf432381ae4eef89f6?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Good afternoon,
I am trying to true up my delata tablesaw but the blade is out of true by .0035″ This is more than the trunnion adjustment will allow so I am looking as to what might of caused this misaligment to happen? My first indication something was wrong was when I tilted the blade to 45 degrees and the blade cut into the stock metal insert at the rear of the saw. The bearing feel soild and smooth the 5/8″ pin is clean and the mating surface are clean. I could file down the trunnion to make it true but I am sure something else is wrong. Any ideas as to what might cause such misalingment?
Thanks in advance
Mark
Just so we know where we are starting from: Has it ever been in alignment?
If so has it suddenly changed or is this the result of long term drift?
How are you measuring the blade offset from the miter slot: Do you have a Truing/Sanding plate, or are you using a blade?
It has suddenly shifted. I have made many a small boxs in the past with perfectly mitred corners so it was in alignment. As a rule, I typically check it every 6 months or so it is way out now. I am measuring the offset with a dial caliper attached to the mitre gauge. For reference I am using a brand new Forrest blade.
Mark
Contractor saws go out of alignment due to the motor hanging off the back, weight and vibration. Usually, adjustments to the rear mounted yoke are enough but you may have to loosen one of the mounting bolts at the front of the trunion when it's out a lot.. You can lay a straight edge against the body of the blade, not touching the carbide tips. The length of the straight edge will magnify any discrepancy more so than just measuring front and back of the blade.
What you are seeing is generally caused by the trunnion being out of parallel. Here is how Delta says to fix it.
You need to remove the blade and leave it at maximum height. Place a flat plate(at least 6"x8") on top of the 2 tie-bars. Use a 3/8" piece of steel but wood or plywood will work as long as its perfectly flat. A pane of glass works well. .Depress one corner of the plate and if it rocks,the tie-bars are not paralell. To correct,loosen the tie-bar locknuts located at the rear of the saw. Grasp the motor bracket and move it to the left and or right. Check the rocking of the plate and when it no lnger rocks,the tie-bars are paralell. Re-tighten the locknuts. As a side note alternately tighten one nut then the other a little at a time or else you move the alignment off ever so slightly.
After you have the trunnions parallel, go through an alignment process making sure your blade is absolutely parallel to the miter slot and that the fence is parallel to the miter slot
Howie,
Thank you! It took about ten minutes to resolve once I knew what to look for.
Thanks again!!
Mark
Yup, it's pretty straight forward. I don't know why Delta (and other makers of Delta clone contractor saws) don't include it in their instruction manual.
