I borrowed a Delta drumsander from someone the other day and it turns out I might own it. Presently it’s destroying my shop and I’m trying to figure out how to absorb it. The owner expressed alot of frustration with it. Well it did accomplish what I wanted it for and some other stuff I decided to do as well. It was slow for sure and the tracking was off no matter what I tried. I’ve been on line and it seems the tracking on that model was a problem for everyone.
I was looking at the rinkidink tracking adjustment and was thinking with a little machining maybe it could be improved. I was wondering if anyone with experience with this model has solved the tracking problem.
I have a Jet, so I can't speak to the Delta. But drum sanders are notoriously finicky. Just a big PITA. It will work great for a while, and then burn up paper for no apparent reason. But they are also the only thing that will let me thickness pieces down to .050", so I learn to live with their issues.
I am trying to use my drum sander on an end grain (maple/walnut) cutting board and I can not avoid burn marks no matter how slow or little I am sanding. Is this just the wrong tool for that combination of end grain wood types? Or what?
I've never used it on end grain, so I can't speak to that. But no matter what grit you use, it's incapable of giving what I consider a finished surface. I use 120 grit almost exclusively, and the scratches left are much deeper than 120 grit on a random orbit sander.
If it was me, I'd use it to level the cutting board and then use a random orbit to get the final surface.
