Delta Model 37-285 Jointer Fence Mounting Bracket Assembly
The fence mounting bracket on the Model 37-285 jointer is made of pot metal and mine disintegrated. The part has been discontinued. Does anyone have a good solution for making a replacement or if there is a 3rd party replacement available?
http://www.vintagemachinery.org. Place a add. Someone may have it or know where to get it.
Good Luck
I've known people that don't want to bevel their fence, and just have a piece welded on. You can't bevel, but it's rock solid, and always at 90 degrees.
Thanks for the inputs. I thought of the 90 degree weld but was hoping for a replacement alternative. I’ll try Vintage for that. Thanks for both suggestions.
