I just bought a used delta radial and plan to use
a dado set. I’m sure I’ll need to remove at least one of
the blade flanges. Will this be of concern? If so, what is
the solution?
Ken
the solution?
Ken
I don't think so. Every Delta I have seen holds a full three quarter inch stacked Dado set.
I wouldn't want to remove any of the flanges, but the outer one would be the only one I would be tempted to remove.
Boris
Boris:
Thanks for your comments.
Ken
I agree with Boris. I don't think you should remove either of the blade flanges. On a related safety question, can you use your blade guard with your stacked dado set? I've got a 12" Dewalt contractor's RAS and don't believe it's possible to use the blade guard with my dado set assembled on the arbor. All those exposed blades make me a bit nervous so most of my dados are done with a table saw or router.
Chip
No, I would take off the blade guard when dadoing.
Yes those blades spinning at 3450 do give me pause, but it is really not much different than a table saw dado set up. Three exceptions: (1)In a TS, the 3/4 of the blade is burried below the table; but (2) In a TS, when the saw kicks back, it kicks back at you, in a RAS, the force of the blade simply forces the wood back onto the fence, a much more safe set up; In a TS, your hands are dangerously close to the blades unless you use push sticks, in a RAS, you have a nice handle which keeps all fingers safely away from the stock. Dadoing in a RAS might actually be safer than in a TS.
Boris
