I cannot find “Denatured Alcohol” here in Canada. Would it be know under some other name?
Methylated spirits
Go to your hardware/building supplies store; they'll have methanol and possibly ethanol. Or your drugstore: rubbing alcohols are either ethanol or propanol- it'll say on the bottle what it is.
Denatured alcohol is typically grain alcohol (ethanol, the kind in booze) to which a toxic substance, typically methanol (wood alcohol) has been added to make it non-potable. In Britain, this is known as methylated spirit, or meths.http://www.newton.dep.anl.gov/askasci/chem00/chem00102.htmIsopropyl alcohol (isopropanol, IPA), yet another kind is what is found in rubbing alcohol. The problem with drug store IPA is that it contains about 30% water.Though any of these can work as a shellac solvent, they will provide different results and drying rates. For example, methanol dries (flashes off) very fast, and isopropanol medium slow. Denatured is in between.
As others said, if you have the queen on your currency, you're looking for methylated spirit. For fine work, I often use Behkol, which is a ridiculously expensive but a shellac solvent that gives very predictable results.
Pete
I have been using methyl hydrate which is available at Home Depot in Canada
I have also purchased it under the trade name, Bekol.
