Can anyone help me find some desert iron wood. from my understanding it is sold by the pound and I am needing about 100 bdft for a cabinet.
HA HA HA HA HA!!!!!
Better do a little research. Biggest pieces of desert ironwood I see are bowl blanks and small (under 18" long) boards with wane, cracks, defects, etc. I don't believe it's legal to harvest the live trees so as dead trees are found they are usually cut up into smallish pieces to drag out of the desert. Not to mention it's one of the hardest and heaviest woods I have ever worked (well, snakewood is a little harder).
If you buy it by the pound I hope you get it for $.25. Oh, and I'm not absolutely positive but I think the full grown adult trees are still pretty small and completely gnarled and twisted, preventing anything even remotely close to what's considered a "board" from being able to be produced from the trunk.
Good luck,
Lee
You don't have your profile filled out so we have no way of knowing where you are located in the country (or the world) but you can try Gilmer wood products:
http://www.gilmerwood.com
they usually have some in stock or may be able to point you in the right direction
Would you possibly be thinking of mesquite instead of ironwood? I'm not aware of ever seeing ironwood in planks.
Ron
CHS
In case you are looking for mesquite (sometimes called ironwood), I was just at two mills in Arizona. Tumacacori Mesquite has a lot of stock on hand. http://www.mesquitedesign.com. there are several other sawmills in Texas if you google mesquite sawmills.
Thanks for the info. I have a couple samples coming.
