I am trying to trace an article on a home made “reciprocating band saw”. If I remember correctly it consisted of 2 parallel beams, one above the other, each pivoted in the centre. At one end was a strip of bandsaw blade and at the other a tensioner. These 2 beams were connected to a motor which caused the blade to reciprocate up and down as the beams were rocked on their pivots. The ends of each beam had a short curve centred at the pivot which allowed the blade to move in a straight line. Can anyone help me track down this article or any design details.
Old China,
I think you are referring to the Walking -Beam Saw-an article by Mark White that was in Fine Woodworking mag. September 1980.
A wicked machine indeed-capable of gobbling up huge forests-just remember the machine is only as good as the blade-so if you equip it with a 2" wide band saw blade you will have to eat lots of corn flakes for breakfast and the box.....
From the picture in the mag I can see that comrade Mark has Huge Feet and a determined expression on his face.
Keep us posted!
Thanks for the info. It sounds like the design I'm trying to track down. I'll try and find the issue you mention.
Cheers Mark
Reminds me of that peddle lathe that that I saw somebody make on PBS TV!
That would be Sir Roy of Underhill, The Woodwright's Shop.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
You are referring to a walking beam saw. I built one about 15 years ago, when I bought a bandsaw I took it apart for parts.The saw worked , but not anywhere as well as a bandsaw. Even with a bandsaw blade the lumber wants to pull up. The heavier the stock the easier it is to cut. You will have a difficult time cutting anything lighter than 40 lbs. The blade will pull the stock up on the upstroke. You can reduce the pull up by making the saw blade orbit instead of straight up and down. This only will work in the crosscutting variation of the saw. You cannot make the saw orbit in the rip mode. I built my saw for about $10.00. I had everything but a few misc. bolts.
Do not let the reciprocating saw go faster than 150 rpm's. You need a large flywheel even with a 1725 rpm motor. If I recall I made mine 20" in diameter.The flywheel was made from three pieces of 1/2"cdx plywood.
Buy or borrow the book Making and Modifying Machines, a taunton publication I think.A smaller version of the saw I built is well described in this book.The author uses a pruning saw blade, I would not myself. Tough enough with bandsaw blades.
mike
Edited 6/10/2005 2:36 pm ET by MIKEK4244
Thanks Mike.
My plan is to use the saw to convert some Red Gum Railway Sleepers into usable sizes as they are too big for my circular saw. I am at the design stage at the moment so will take your recommendations into account when I understand how the machine operates.
Cheers Mark
walking beam saw.. I saw a really old pic.. USA.. Old jacks cuttin through a really big redwood (what a shame).. One on top and one on the bottom... I think the guy on the bottom was a apprentice cus' gets all the sawdust!
Will, are you referring to pit sawing? My great grandfather was a pit sawyer, bottom man. The story I was told was, you put the biggest and dumbest man in the pit.I'm told I'm a deadringer for him.
mike
But I think the 'CREW' had to pay for his drinks at night so he would go back to the job the next day without a fight! LOL...
Hi Will, Interesting about the pit saw, sorry to butt in.
I understand that the expression "Underdog" relates to the poor fellow down among the sawdust.
Cheerio
Woodsy
Woodsy,
I believe you are trying to rectify a thread which has gone bottom up.
I just don't know when to keep quiet. lol
Woodsy Butt in? I think it was your post?
