I need to build a range hood cabinet to fit the space in the picture below. Cabinets are hickory, doors are traditional, space where the range hood goes is tricky. The cabinet does not have to have doors, but will need to go around the beam in the picture. Cabinet space on the side of the beam, could also just have a solid face and be dead behind it. Just looking for a few other ideas.
Eric
“When it comes time to die, make sure all you have to do is die.” -Jim Elliot
It would appear to be an exterior wall. If that is so, have you considered a vent direct to outside instead of up? The hood could then be below the beam.
Maybe consider using a non-vented type. They have an internal filter that needs to be cleaned/changed from time to time, but no vent to the outside at all.
DR
Thanks for the input. It is an exterior wall. The non-venting hood may have to the only option. We can't bore through the wall because it is solid studs supporting the beam. However, that is beside the point. I aplogize for not making myself clear. I am looking for ideas for the cabinet design from the top of the hood, to the ceiling and around the beams. I would like to do something other than dead space. Maybe open shelving?....I'm not sure.Thanks,
Eric"When it comes time to die, make sure all you have to do is die." -Jim Elliot
It's a completely subjective thing, but I really don't like the feel of wrapping a cabinet (fake or otherwise) around that beam. It just doesn't feel right. There's an old eastern story about how the excuse is worse than the sin itself, and I think that's the case here. So I'd end the cabinet below the beam, not even touching it. Other possibility would be to use the beam to create something new - like if you attached a wide plank along its underside, creating a bookshelf facing either way, or something like that. Still, I wouldn't touch the beam with the vent cabinet. Maybe use a vent like Viking's stainless recirculating unit, which is not meant to be hidden at all, and shift the eye to the beam above. DR
