As an amateur woodworker I volunteer for my church. I am organizing other trades people to assist small churches with renovations, upgrades, and small scale remodeling. Can anyone recommend some fairly simple design software that could show floor plans and 3D views. Jim
A program I use regulary is Microsoft Visio. It allows everything from full building plans to floor plans to detailed engineering drawings. I've found it very easy to use as i didn't want to get into the time and learning curve that I think would be needed to master programs like Autocad.
Hope this helps
edcross1
edcross1, many thanks. I'll check it out. Glad you said what you said about Autocad. Looked at that once and came away with my head spinning. Jim
EdCross1,
Have you used Visio to design furniture. I already know it so I'm thinking of at least trying to use it for designing furniture. I'd rather not buy another package and have to learn it.Regards,
Buzzsaw
Jim:
a great CAD package I use - costs $895 but worth every penny - is called Rhino 3D... they have a fully-functional evaluation copy you can download to get a flavor... if you know windows already, it takes about 8 hours to get 90% up-to-speed
http://www.rhino3d.com/
Michael, thanks for your suggestion. Price is a bit stiff for church volunteers but I'll take a look. Thanks!! Jim
Jim, if you want a cheap program to get your feet wet, take a look at Broderbund's 3D Home Architect (http://www.broderbund.com/Product.asp?OID=4147877&SC=1105635&CID=20). If you can find a non-current edition (try Wal-mart and the likes) of the software, it will even be less expensive. It is true you get what you pay for, but this little program might surprise ya'.
B9, I've seen it on shelves at places like Staples so I know it's available nearby. Thanks, I'll give it a try. Appreciate the tip. Jim
Jim, I have no suggestions on what to buy but I would warn you against TurboCad. I bought a copy for about $100. It sounded as though it could everything I needed. When I opened it there was no manual and none was available; no books, nothing to help you learn how to use it. The only way to learn was to buy tutorials, many of them, all costing tens of dollars apiece. trying to figure it out alone resulted in all sorts of traps and pitfalls.
Good luck.
David H.
David, many thanks. I feel properly warned. Jim
