Anyone out there make a bench for their lathe they really like? I just bought a nova lathe (3000) used, and without a stand. I get the basic theory – heavy and solid. But how did you deal with storage, dust collection, and clean up? Storage and sand bags both? put sand bags as near to the spindle as possible? or down toward the feet? Are casters just out of the question? (at the moment i’m roughing 15″ heavy wet large bowls)
thanks!
I purchased my lathe new and it came with a sheet metal stand. I gave the stand to a welder and asked him to make a duplicate stand in 1/4 thick plate steel. It's a beast and not a drop of vibration. Before mounting the lathe I used a 3/4 inch ply under the top surface of the stand to further deaden vibration. No regreats to this day. Stand in service over 30 years. When I was into turning bowls the lowest speed on mine was 600 RPM - still much to fast but newer machines have speed controls. A slower speed will serve you better than a rock solid stand for large wet green wood.
SA
Only 1/4" thick steel plate? ;-)
Sounds like a great stand.
lathe dust collecting
Not a whole lot can be done about chip collecting, but sanding dust can be somewhat controlled by placing a "big gulp" chute behind the piece.
No expert here, but . . .
. . . I'll share my thoughts, anyway.
I have an old, light-duty Delta lathe - far too puny to turn bowls of the size you are working on. But, it does sit on a heavy steel table that is supported by cast iron legs. With a couple of bags of Quik-Crete on the bottom, it's pretty stable.
I like Westchester's suggestion of a plywood spacer between the lathe base and the table to dampen vibration.
As to casters, I've seen heavy-duty ones that are cranked into position, but have a solid base for the machine to rest on during operation. That type of caster would allow occasional movement, with some effort. I've also seen "creative" designs that use a pair of scissor jacks to raise the base onto casters. The right approach, I suppose, depends on the total weight of the machine.
Thanks all of you for the ideas. having a welder do it sounds great, but beyond me, so I'm thinking 4x4 frame/legs, m&t joints and a built in for tools. Plywood for dampening is interesting - i actually have some heavy duty rubber pads - maybe i'll try them....
appreciate it!
Angles?
Some years back, I made a wooden base for an old, second-hand lathe. I angled the legs like an "A" shape to make it more sturdy, while keeping the top relatively narrow.
Designing a bench for a lathe
I just got a Nova DVR and made a bench based on the workbench that Fine Woodworking has on the sister site Start Woodworking. The bench is solid. I used the dimensions in the Teknatool manual that can be found on their website on pg 10. I combined the plans and put it on a mobile stand. Put the bottom shelf a bit lower. I also made the top 2.25 inches thick. It is solid doesn't vibrate and I haven't put sand in the stand. It is solid.
if you would like I can post some pics.
I'm really late coming to this party - like 7 years from the original thread. However, I have come up with an effective solution for a lathe stand.
I have a Nova midi-lathe. It's not really heavy but has enough cast iron heft to sit solidly, without movement, when it's in use. For the stand, I used a fairly heavy metal frame originally designed as a sofa-table base, roughly 12" x 48". It was purchased from Rockler. The top is 2 layers of 3/4" MDF, with the top surface having a phenolic coating. I fabricated two shelves using wire shelving originally designed for closets. That allows dust and chips to fall on down to the floor and not collect on my tools.
The original post asked about using casters. I used medium-duty locking casters and have had no issue with them. Maybe if you have a larger lathe and turn large bowls you might have a problem, but so far I have had none.
I'm sure you've long since built you turning bench/stand, but if another new turner reads this thread my comments may be useful for them.
I bought a cheap 3'x5' K-Mart workbench, used 1" hickory for the lathe to sit on, stiffened up the legs with 2x4s and haven't had a problem in 7 years.
Mikaol
