Dewalt 12″ chop vs Dewalt 8.25 sliding
I was looking to get the Dewalt 716 12″ chop. It bevels both ways and has good capacity. But Woodcraft had a 712 that I could get for 10% off and another 10% rebate off. So I opted to buy at the sale.
Any opinions on either of these? I haven’t opened the 712 yet. The only thing I don’t like on the 712 is that it doesn’t bevel both ways.
Steve
Guess I should add, my main purpose is trim work in my house and cabinet building.
Steve
As far as trimming out a house is concerned, the main value of a 12" miter saw is its greater capacity when cutting large crown moldings.Many carps struggle along just fine with a single bevel saw, but I vastly prefer the convenience of a double bevel.********************************************************
John Wooden 1910-
Edited 7/29/2007 3:46 pm by nikkiwood
Your question is a tough one. All the trim that goes into normal (even higher end) homes can be cut on the 716. It is rare to find 8" one piece mouldings. given that the 716 is a lot better. If you know that you will be working with unusially wide mouldings then the slider is the way to go. I have needed the sliding saw's capacity twice in the last 4 years and I rented one at Home Depot for $20.
Pardon my spelling,
I bought the Dewalt 712. It's a good saw and worked well for all the trim work I did in my house. I wish it beveled both ways, but that wasn't really a deal breaker for me.
Trevor
Thanks for your input. I have been looking/googling for any 712 reviews and have not found one on the web. So I came back here for some advice.
I got the 712 based on input from the guy at Woodcraft. He does a little trim work and mostly cabinet work. In his selection of a Dewalt chop, he felt the smaller blade presented less deflection problems and has not added a stabilizer to it, a concern he would have with the 716 and that 12" blade. I was going to check into Forrest blades for this as I love my tablesaw and circular saw Forrest blades.
As far as crown, he isn't building any really large ones and I wouldn't be either so that didn't seem to be a big issue. He wasn't concerned about the bevel only because he uses a BenchDog crown jig and that pretty much solved his issue for the single bevel.
Will also look at some Amazon comments tonight too.
Hard to believe I haven't found a review on that 712 though. Usually every mag does at least one on these saws. May have to look for a cousin of the 712 that was reviewed.
JLC (Journal of Light Construction) did a slider review about 2 years ago. Maybe more reciently. They included 8" saws. The models haven't changed so the reviews should be accurate still.Pardon my spelling,
Thanks. Saw they have an article in 2004 but you have to buy it. That's 3 years old and I would think it's accuracy is getting a little long in tooth. There have to be some upgrades in these saws in 3 years. I would guess.....
Actually i dont think there has been any changes. I will look for the article in "the pile" to see if I still have my copy.Pardon my spelling,
Thanks for checking.
I have one of those 'piles' too, thanks to Finewoodworking.com.
Steve,
Let 'em all howl but a RAS (Radial Arm Saw) will cut bevels all the way home. Mine handles up to 24", just clean 'em up on the jointer.
Keep 'em on the 90 and use jigs to set the angle. Gotta love it!
And they're cheap.
Edited 7/31/2007 9:23 pm ET by KiddervilleAcres
Edited 7/31/2007 9:24 pm ET by KiddervilleAcres
Edited 7/31/2007 9:50 pm ET by KiddervilleAcres
I have a 50's era dewalt GA and I agree that it is a superior machine in every way.... except it weight 500 or more pounds! For finish carpentry that won't cut it, so to speak.Pardon my spelling,
I have the 12" dual bevel Dewalt.
I got to tell you; I rarely (if ever) use the dual bevel. My experience tells me to recommend to you the 12" single bevel design.
For trim work the 716 or the earlier model 706 are hard to beat. They can cut all but the largest mouldings in position. With a little jigging I have cut 8" crown in position on mine. I feel that cutting in position is more accurate than on the flat because you are relying on the accuracy of a scale with a +/- 12" radius rather than one with a +/- 5" radius. Odds are you'll be closer. The cut lines are also always easily visible and cutting in this manner for me is more efficient. CMS's have fewer moving parts than a slider so there is less chance of something going wrong. Once tuned up they stay that way. I check mine once a week and rarely have to adjust it. They are accurate and durable which is why most trim carpenters I know, including myself use them. Full kerf blades almost eliminate deflection. A blade stiffener on these saws would take away from their cut capacity. The single bevel CMS 715 does not have the capacity the 716 has with crown as the motor gets in the way.I have used the 712 when helping out a friend. It has roughly a 3 1/2" vertical capacity. It was a decent saw and was accurate, but like you said it only bevels one way which for trim work is slower because it means you need to flip and rotate the material(often 16' long) rather than the saw and requires more thought. He does handrail for a living so the saw is great for him. It cuts through a newel with no problems and the sliding capacity lets him cut most of the waste for a newel notch. For wide boards I rely on my TS55 and a rail. Before the Festool saw it was a Makita sidewinder and shoot boards. Look at what you need out of the saw and what you will be using for most often beyond your own home and make your decision based on that.Justin
