805.1 |
I am considering purchasing the Freud [Freud SD608] 8″ Diameter x 24T Dial-A-Width Dado Carbide-Tipped Saw Blade Set with 5/8″ Arbor Please advise on the Dial-a-Width versus stacked dado sets. Please also advise on the width of this set with all chippers stacked. (I need to know whether it will fit my Kity 10 inch saw.) General information and recommendations regarding dado blades will be welcommed. Kind Regards |
Thanks everybody, it helped. Now just one more question, 6 or 8 inch. My saw should handle both, but will you ever use the 8 inch capacity? Up until now I have not cut any deep rabitts, groofs or tenons.
Edited 5/18/2005 1:49 am ET by FrancoisL
I looked at this set a few months back. There is an issue with shaft length Check their web site. They give the requirements. This only comes into play if you want the maximum width cut (I belive). My cabinet saw could take the dial-a-width and I narrowed my decision down to that blade and the dado king from Forrest. In the end, I went with the Dado king. I use Forrest blades on my TS,RAS, and CS. The quality of the Dado King is outstanding. I like the magnetic shims, and it came in a good sturdy case for storage. I have read good things about the Dial-a-width, and if the shaft of your saw is long enough, the Freud would work. Good luck on the decision.
I have one of the original Freud dial-a-width's and have enjoyed using for the past 6 years. Adjusting the width of the cut is super easy.
About 5 years ago they took these dado sets off the market, not sure why, rumor had it it was some kind of saftey issue.
Finding somebody to sharpen them is a interesting. Last time I had it done, about 3 years ago, Forrest wouldn't touch them. Now that Freud is making them again I'm sure they have a source.
Joe
Joe,
According to their website, Each "click" of the dial adjusts the blade by .004"
Unfortunately, I couldn't find where it said the maximum adjustment provided by the dial-a-width mechanism.
Do you know how many "clicks" of .004" each their mechanism provides? In other words, how much can you expand the width of the dado before you have to add a chipper?
Thanks,-Jazzdogg-
jazzdogg
The maximum number of clicks making the dado set wider is 16. At this maximum the teeth on the outer blade still over lap the first chipper.
In the time I've owned this dado set I've never had it not adjust to a given width of cut up to the max.
Woof
Joe
OK. So, 16 x .004 ~ 1/16"
Arf!!!
-Jazzdogg-
Edited 5/18/2005 11:22 am ET by jazzdogg
From Freud:
The hub takes up 7/32" of arbor so the calculation is: Total Arbor Length - 7/32" - Nut Thickness = Maximum Dado Width (up to the manufacturer's stated maximum width).
Or stated another way, arbor length for full width of dado set is 1 1/8" plus the thickness of the nut.
Francois, the Freud Dial-a-Width is a stacked dado. An important distinction between it and the "wobble" style dialing dados.
The Freud Dial-A-Width dado set, as Forrest Girl points out, is a staked dado set that has been designed to eliminate the need for shims and still give the smoothest possible bottom cut. It certainly appears safer than a wobble dado and definitly easier on the arbor bearings. It won't fit on some of the older contractor saws but will fit most of the newer ones. I would not recommend it for a table saw (portable) and doubt if it would fit.
Sincerely;
The Tool Guy
