How can you die maple strips of about so the die will penatrate through?
they will be about 1 wide 3/32 thick. using them for pin strips project in process.
Nothing may get the dye to penetrate completely, but soaking the strips will get as much dye in them as will be possible. You could heat the dye to speed up the process.
Don't sand above 220 before applying the dye; maple can burnish at higher grits, where essentially you are sealing off the pores. I'd be tempted to sand up to 150/180, then dye, then smooth at 220. You'll see how well the dye penetrated when you smooth the strips.
As always when doing a new finish procedure, test it out on scrap, first.
Thanks Pondfish
Would you recomend a water base or alcohol?JigSawJohn
I have no reason to suggest one over the other. Since you will be sanding lightly after dyeing, an NGR dye doesn't seem to be critical. If you soak the strips, a water based dye will be easier and more economical. maybe go for best color and light fastness?Recommending the use of "Hide Signatures" option under "My Preferences" since 2005
Another option might be to use dyed veneer, if you can make it work for your project.
Certainly Wood, in New York has wood that is dyed through. I have never used black, but the red I bought was outstanding.
Hal
http://www.rivercitywoodworks.com
Yes Hal that's great. I tried to find veneer before tried to die.JigSawJohn
John,
The problem is that I don't see how you can dye the maple through and through.
I use leather dye when I want something really black, and even that will not penetrate into maple very far. I have never tried soaking it though. I would assume that if you soaked it long enough, and had enough dye to compensate for the rapid evaporation, you might be able to make this work.
Soft maple might do it, if you can get the really white, really soft, soft white maple (there are actually two species that I know of that are sold as Eastern Soft Maple).
Hal
Thanks Hal
I plan to order vernier form collector's Specialty and solve the problem that wayJigSawJohn
I haven't heard of that. What are you talking about?
Hal
They offer red and black died vernier, so rather then die it myself I'am going to try them.JigSawJohn
I think he is meaning to suggest the use of commercially dyed veneer. The commercial products are dyed through and through--probably with pressure or the like.
