I’m curious and I want to know: is there a difference in brands of boiled linseed oil or pure tung oils? Is the stuff at Home Depot or Ace Hardware( I’m talking boiled linseed oil on this one, don’t know if they carry pure tung) just as good as stuff from reputable woodworking stores? Has anyone done a real comparison? Thanks everybody!
I've never run into anyone who has claimed real differences in the boiled linseed oil or pure tung oil commonly available. Now there are some differences among these products--look at a high end artists supply web site, but those are very tiny niches, and many of the differences proclaimed among the varieties artists may choose may be more of the emperors new clothes variety, I don't really know.
But for "popping grain" or for making oil/varnish mixes, I wouldn't worry at all about whether it was from Ace or Woodcraft.
I have used pure tung oils.. I threw it in the garbage! Did not dry well.. Maybe just me though!
Pure tung oil is very frustrating. It typically takes three days to dry, even if will wiped off the surface, it needs sanding between coats, and it takes 5 coats to get an even sheen. And, the end result--a quite unprotective oil finish that can be almost exactly duplicated in appearance by an oil/varnish mix, but in 1/4th the time, with more protection from water spotting, and with no risk of getting a "frosty" appearance if you move to fast.
That's why so many manufacturers make a Tung Oil Finish that contains little if any tung oil and may be either a oil/varnish mix (Minwax Tung Oil Finish) or is a wiping varnish (Formby's). The complaint against such products isn't that they are not good, but that they attempt to sell by misleading consumers that they are using tung oil, around which an almost totally unfounded mythology has developed.
Steve,
Typically only three days to dry? From stories (maybe they are just that) I've heard, pure tung oil can take months to dry. I see no reason to use it.Chris @ http://www.flairwoodwork.spaces.live.com
Three days between coats, in warm surroundings. But to be well cured, you are quite right--it could be months. I don't recommend using it either.
