What is the relative difference between the square palm sander and the random orbit sander? Why would you use one over the other or should you use both?
Thanks.
Thanks.
Orbital palm sanders run in a fixed orbit and therefore leave an orbital scratch pattern which is more visible than the random pattern left by an RO. I have 2 RO's and 2 oribital palm sanders. I use them for getting into corners and on round overs. I use them before the RO. On the RO's I use hook and loop disks. On the orbitals I use the Trimite PSA papers that come on rolls.
RO sanders are a vast improvement over orbital sanders. I have used both, much more than I’d like to. The RO sander is more aggressive, but has less of a tendency to leave swirl marks, than an orbital sander. I use my orbital sander to level sand between coats of varnish, where its being less aggressive is a blessing, other than that I have no use for it. I have three rules for all finishing sanders, 1 never use anything more coarse than 180 grit paper, 2 move the sander slowly, and last but not least, don’t think of a sander as a tool to remove stock, doing so always results in substandard work. One exception to this last rule is I use 320 grit to break sharp edges, as I do the final sanding before finishing.
