Need a littke advice on how to dismantle a 30 year old excutive style wood desk. My attempt is to reuse the wood for a laundry hamper. Is there a good way to start without damaging the wood?
Bill: Yep use a 8lb sledge instead of a 12lb one LOL... Just take your time and be as careful as you can while taking it apart..
ToolDoc
You could always set it over a heater vent for a week or two. Get in some good expansion and contraction cycles! There are some small pry bars out there that work pretty well on furniture -- I think one's called a cat's claw. I sometimes use a tack remover for small stuff (look around where the screwdrivers and stuff are at the hardware store, handle's like a screwdriver, but the thinnish tip is curved and split).
Your best leverage is going to be with the legs. Try turning it upside down, get your kids or a large dog (or horse, LOL) to sit on one end, and push/pull/rack the legs on the other end to get some loosening started. A rubber mallet would be handy too. If you get a weak joint, you can knock it apart without causing too much damage.
Edited 11/15/2002 5:38:54 PM ET by forest_girl
white vinegar softens PVA glues.
If all else fails (you can't re-use the joints anyway) take a small blade on a jigsaw and cut it apart.
You might be lucky, in that an 'animal' glue was used in its original construction....that being the case the application of heat to the joints is a valid approach ... a hair dryer will generally work albeit time consuming....once good and warm/hot... gently expand the joint.
It'll take you a bunch of time, she'll hate you for stealing the dryer, you'll argue the value of you're action...and as always lose....at which point you'll be totally justified in taking the hammer to the desk....and ya know what it'll feel great and still generate the wood you need.....have fun regards Iain
