My son has a small dining room and wants me to build a dining table that would accomodate at full size. Two questions – 1) what are the pros and cons of an extension table vs. sides that swing up? 2) where can I obtain plans for one or the other?
Hi Willy,
We've written a whole lot about table design in the magazine so I'll refer you to a few great articles on the subject. But generally, there are a few things to consider.
First there's size and dimensions. This article by Graham Blackburn covers the subject in great detail and is the best place to start no matter what style table you make. Depending on the number of people you want the table to seat, dimensions are critical.
A drop-leaf table, where the sides fold down, has to be carefully designed so that when the leaves are down, a person can still fit his/her legs underneath. If the leaves are too big, you end up hitting your knees when seated. The Shaker-style drop leaf table accounts for this pretty well. Here's a nice article on building one of those. The rule joint that enables the leaves to hinge is challenging to build but worth the effort.
Personally, I like the extension table. The only problem is finding a place to put the center leaves when not in use. With extension tables, the critical question is what mechanism to use for the extension. There are a number of types of commercial extenion hardware or you can make your own. Check out this project article we recently published for one idea, and browse the Tables section of our site for more plans.
That should keep you busy for a while. Write back if any other questions come up.
Matt Berger
Fine Woodworking
