I’m looking for a good finish for a dining table. The table is Carpathian Elm Burl and Australian Walnut Veneer. I have finished the table with Minwax Oil Base polyurethane but I am not happy with the durability. I have sprayed about 12 coats on the table. I want to scuff down and apply finish over the top of the poly. Does anyone have any experience with a more durable finish?
What are looking for in "durability?" 12 coats of poly is getting to the point of solid plastic and there is not much that will be more durable.
While I don't recommend it, commercial and professional finishes like catylised lacquer are much harder. But, they need to be applied to virgin wood and are very dangerous to use.
I'd suspect it's not as durable as it sounds. Unless they're very-very thin, 12 coats doesn't improve your protection. On the other hand, there are other brands of poly and varnish that are specially formulated for tabletops. Try
http://www.homesteadfinishing.com/OILSVARNISHES.htm
and look at both McCloskey's and the Behlen Rockhard. Also pay attention to the recommended film thickness, however you apply it. For instance, 12 brushed coats is far more than 12 wiped coats, so I'm unsure just what you applied.
Gerry
