My next project is a Dining Table with slides. Are slides easily built or should I buy them and if bought where is a good source?
There are a few different types of slides. Van Dyke's Restorers carries some. I'd buy them.
Willy,
It is not very difficult to build your own slides, but you can buy reasonably good slides from Rockler. I think it is a waste of time unless you want the satisfaction of doing your own. There was a good article by Jeff Miller in FWW within the last three years showing how to adapt heavy duty glides to this end.
Check out Rockler: http://www.rockler.com/CategoryView.cfm?Cat_ID=146
I have used the equalizer slides on a pedestal table and the extension slides on a traditional table with two leaves. Beware of the equalizer slides on long tables. They have limited length capacity that is not adequately explained in the catalog.
Good luck, Tom
Willy,
I just finished a dining room table and used 52" wood slides from Classic Designs by Matthew Burak. http://www.tablelegs.com
Very pleased with them.
ASK
The last time I bought slides was from here:
http://www.paxtonhardware.com/products.asp?dept=201&grp=1
I bought the #4697 and the table was VERY heavy, 8' total length
with 2 24" leaves. I had to make a 'leg' to support the table when open.
Metal slides may have eliminated the need for a center support, but I doubt it, and the wood slides were appropriate for the table.
pins
Depending on the size of the table, wood slides work well for small or medium sized ones. A larger table would require something sturdier. Check out Rockler, they have a wide variety. If your table will have more than two leaves, build a platform under it for their storage. This can be easily built and you have access to them when needed.
