I’m building a crooked barn playhouse for my grandson. I will use cedar boards nailed vertically. I plan to prime the cedar on 4 sides with white Zinzer 123. Is there an easy way to get a distressed barn red finish? I’m not sure what the end result should look like…except like an old barn. I’m open for suggestions.
You get out of life what you put into it……minus taxes.
Marv
If I am interpreting your "schedule" correctly you will have a white barn and then want it to be red with some of the white showing through. If that is what you want you can put vaseline on the barn before you paint it red. Those areas will stay white and then you wipe it off.
For an old barn look, I would skip the primer and use milk paint, which comes in the barn red color. Now I am talking about actual milk paint, the kind you mix from powders. Extremely durable, yet if you don't top coat it it will pick up some water spots and mottling that will give an old look very quickly. Milk paint works best over bare wood--if you prime it first you will have to add an acyrlic additive for adhesion, making it more like acyrlic paint than milk paint.
Milk paint would look great, here's the link to the best stuff:
http://www.milkpaint.com/
I would not prime with white, because when you distress that white would show through. You could probably call the folk at OFMP to get some ideas, or with luck, Gretchen will show up here, she usually has some good tips.
I think the milk paint would be great also. If it is desired to have something show through, the vaseline could still be used, and it would be bare wood showing. Then the OP could rub in some stain to darken that wood. Not sure what kind of distressing is desired exactly.Gretchen
Thanks to all. I'll go with the milk paint. Picture to follow.You get out of life what you put into it......minus taxes.
Marv
Mary - Might be too late for this, but if you want a crackle-type finish so that the barn red is cracked with the white showing underneath, there's another (and in my opinion, better) way to do it than with vaseline. You paint on the white (or other) color first, let it harden overnight, then brush the surface where you want the crackle with liquid hide glue. Let that dry, then overcoat it with the red. The red will crackle as it dries.
Here's a link:
http://www.jonespg.com/paint_tips/Jones%20Paint%20-%20Faux%20Finishing%202.pdf
I think you have to use latex paint.Gretchen
It does work with milk paint as the top coat - I've tried it. Seems the re-hydrating and then subsequent shrinkage of the hide glue is what does the crackling. I presume if that's the case then one would have to use a water-based paint, though.
Another way to do it with oil-based paint is with a blowtorch. I've also done that, but I don't really recommend it, as it stinks and it's pretty easy to go too far and char the paint.
Interesting. I guess it is because milk paint is water based. I do know you can control the degree of crackling by diluting the hide glue (if you want a finer crackle). The thing I dislike about crackling is that it usually looks so fake--too big a crackle, although on a barn, that could be a good thing.Gretchen
