DIY Manometer for Dust Collector
I was interested in somehow connecting a DIY manometer to my Grizzly G0860 to monitor the filter cartridge efficiency. Has anyone tried this? If so, where did you drill the hole to place the manometer tube?
Dave
I have seen this done on YouTube - the meter was placed near the sucker.
Commercial shops do have monitoring so they can ensure they are reaching acceptable standards and to indicate when a filter change is needed, but it is hard to see the value in a home shop. Whether or not it is collecting the chips is a more useful measure.
Large Commercial dust collectors measure the pressure difference between the clean and dusty side of the unit to trigger a air pulse that releases the dust cake to fall in the auger screw and be carried away. In the case of a canister sitting above a bag, the clean side pressure would be the ambiant room pressure, the dirty side pressure rise could be measured just below the canister and a set point to clean the canister determined by trial and error.
I spin the handle on my DC now and then, and empty the bag when it needs it. As long as it's sucking well, I don't worry about it.
