Do 600+lb capacity. mobile bases exist?
I’m presently considering purchasing Powermatic’s new 8″ parallelogram jointer that weighs some 600+ lbs. I’ve even considered Oliver’s 10″ jointer but at 1000lbs… I’m way at a loss as to how to move the dang thing short of gettng a forklift! Maybe I’m just dreaming too big for a home shop. But really, are there any mobile bases out there that will handle 600-700lbs?
Grizzly's new 8" parallelogram jointer has an integral mobile base...
So what exactly is the advantage of parallelogram beds on a jointer? Is this another adjustment that can be thrown out of whack?
The p-gram design maintains both the infeed and outfeed tables closer to the cutter head. I think Deta introduced the design ~15 years ago. I'm not sure if it has much pratical advantage over the DT way design, but it will stay true. Since I tend to take light passes with my jointer (which is a DT design), my tables stay pretty close to the cutterhead in any event. If you use your jointer to cut rabbets, then a p-gram might have an advantage. I'd be curious if anyone with experience with both designs has a preference and if it is practical or theoretical...Glaucon
I'd be interested too, if someone could shed light onto which design is better practically speaking. From a calibration stand point more moving parts equals broader overall tolerance specs.
I picked up a Shop Fox HD unit a few years back for use on a monster drill press that's something like 600-700 Lbs. I think the base was rated for use up to 1200 LB. It's the adjustable size type with bolt holes every inch or so to size it to the machine base.
If you build it he will come.
My Oliver 299 (18" cast iron planer) weighed about 1600 lbs. It was built before mobile bases and dust collection systems existed (1927). I made a dolly on 4 heavy duty wheels with some 8/4 white oak, and recessed it up in the base, and set it so the planer rode about 2" off the ground. I've seen both ends of a 24" jointer supported by the same type of shop made dolly (it's where I got the idea from!). I'm pretty sure I invested less than $30 and an hour in the shop to make it. It worked great, and when I sold the planer, the dolly went with it, so it's still working.
Wow! A 24" jointer?!!! But hey, thanks for the idea. I actually had thought about making something like what you mentioned but didn't know if it would handle the weight. But if it worked for you, I'm sure I can come up with something. I think I may reconsider that Oliver jointer afterall.
nomas99,
Something to think about...If you decide to go with a Shop Fox, like most mobil bases, there are two fixed wheels and two 360 wheels. Grizzly was able to identify suitable wheels so that I could swap out the two fixed and have 4-360's on the mobil base...each wheel cost about $4-5.00
The part # for the mobil base for the Powermatic PJ882 jointer is 1610078. It has a list price of $229.00 You should be able to get one fron your powermatic dealer. The web site has a look up for dealers .. Good luck
http://www.wmhtoolgroup.com/index.cfm?area=shop&action=dealersearch
Thanks for info!
Jet makes two of 'em I've seen: one with a 600lb capacity, and one with a 1,200lb capacity. They assemble very quickly and easily without tools. The local Rockler (San Diego, CA) sometimes has them in stock.
-Jazzdogg-
