Hi, queen ann style table, split in middle, w/ slides, will have 2- 12″ leafs, assume al table cloth whenever leafs are used, so do i need to add 12 aprons to leaf , can any oner really see if i skip them? storing a flat leaf beats storing a few leafs w/ skirts Thanks, dave
Dave,
I like the idea of no apron on the leaves...much easier to store.
Just guesing here... but don't the aprons help keep the leaves nice and flat while being stored?
I also like plain leafs w/o aprons, and am ASSuming a properly finished leaf, on both sides, should stau flat, but I am looking for opinons so I do the right thing. Thanks
As long as you you have locater pins or dowels on the leaves,no aprons are necessary.
Most of the older (1930's - 1940's) big dining tables I've seen did not have aprons on the leafs. Many of the nicer ones included a storage "container" (made of wood) with dividers between which to slide the extra leafs before putting them in a closet somewhere.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Dave, If it's a real 'Queen' (wink wink), at least one apron is 'de rigueur'
Martha Stewart reccomends a floral print for the 'Domestic Chic' look.
If not sure, Don't ask-Don't tell. Stein.
I've seen leaves both ways -- with and without aprons.
My dining room table is from the 50's, and is Pennsylvania House. The leaf is sort-of self folding and self storing. I pull the table apart, then fold the leaf in half. In the process of folding, it gets turned upside down, pivoting on a rod that is part of the table. As a result of that fold, it is hung on the rod. The table then closes over the folded leaf.
As a result, my table leaf has no apron.
