Hi, friends.
I’m starting an art project about dollhouses. Recently blocked about clapboard siding simulation.
I saw a Jim Partner’s tip to do it but I don’t understand the way to do the bevel subbase.
Can anyone explain better?
Thanks in advance.
J. Vega.
You can just buy it in sheet stock.
Search online for "architectural model building supplies".
Thanks for your answer. The thing is that I want the "real" effect of clapboard siding not just making cuts on a planar surface, sorry if you understand. There is a example attached.
Some companies make dollhouse kits with pre-milled siding. This is the effect I want. Looking for an article inside Finewoodworking I found an old reference but is not clear to me.
SOLUTION FOUND!!
Just got the right picture where you can see perfectly how to do it.
Thanks!!
