Do you recommend doug fir (straight–grain) for steam bending? Pieces will be anywhere from 3 to 5 feet in length, and 1 to 1 and 1/2 inches wide and thick. Thanks so much. Paul
I doubt you will have much luck steam bending solid Doug Fir, it is quite brittle and has a tendency to de- laminate, for lack of a better term. The summer and winter wood seperate, leaving a sharp edge up ready for a splinter. I have done bent laminations with it, though, and it worked very well. Use the tightest, straightest grain you can find, and I stress tightest because the older growth wood with very fine rings splits and chips a lot less. When you do a glue up, make sure all the grain runs the same direction so clean up(milling) is a lot easier with less chipping.
