While looking at photos on WoodGuy.com, I came across a photo of a dovetail splice. I’m new to woodworking and have never seen this before. My curiosity has had me looking around for articles and or how to’s for the dovetail splice, but I’ve had no luck in finding any.
Will you do an article or video and explain how to create one of these joints?
Dave.
Edited 4/30/2007 4:36 pm ET by MrDG
HI Dave,
I'm not sure what you mean by a dovetail splice. Do you mean a dovetail key? These are inlaid into two boards to create a joint of sorts between them. They can also be inlaid into a crack to prevent it from growing. Check out George Nakashima's book Soul of a Tree for that.
If you mean a lapped dovetail splice joint then that's different as you're splicing together two boards with a dovetail in between. I believe both joints are covered in my Complete Illustrated Guide to Joinery book.
Have fun.
Gary,
Thanks for the reply. I'm not talking about a key and I'd foul things up trying to write a description. Here's a link (http://www.woodguy.com/berry20.html) to the previously referenced pic. Any further info you can share about it would be much appreciated.Dave
I'll throw in my 2 cents worth here, the joint is made by running two dovetails diagonally across the square cross section of the two ends of the pieces being joined. In the photo, the dovetail at the top runs to the back of the rail, and the the dovetail on the front face comes out at the bottom. Made in this way, the two male and two female parts are parallel to each other so the joint can slide together.
This is a weak joint but a fun brain teaser. To make it, you would have to make a jig for the router table that would stand the pieces on end so that you could feed them across a conventional dovetail bit.
John White
Hi Dave,
This joint is done with angles, not mirrors. The dovetail slots are cut on angles as are the tails that slide into them. The angle is cut from one side face to one top face. It is all for show.
Gary and John,
Thank you both for the feed back.
Now I'm off to the shop to see if I can make one.Dave
