Hi
I have written a Dovetail template generator that you may find useful
Enter the dimensions of the wood, and tail setout and it draws the template, ready to print, fold over end of wood and cut through.
It lives here
http://www.blocklayer.com/Woodjoints/DovetailEng.aspx
VERY cool! Any help file to explain a little better the variables that you need to set? Thanks for this resource. Bookmarked "fer sure".
Mike Hennessy
Pittsburgh, PA
I tried it, printed it out -- and my pattern was crooked. At a about a 45 degree angle. Any suggestions?
Alan - planesaw
Did it display on your monitor to scale and oriented correctly? I've never seen it come out at 45 degrees before. What were the measurements and tail settings you used. I'll take a look and see what happens
My monitor was correct. I used your default settings. I have an HP laser printer. The problem was only on what printed out. It was slanted at about 45 degrees.
Alan - planesaw
