dovetails by bandsaw or jigsaw
Hi:
New to this forum. Want to cut dovetail tails with a bandsaw. Any blade recommendations and where I can buy them?
Would a high quality jigsaw cut the pins also? Festool or Bosch?
thanks
sbolton
Hi:
thanks
sbolton
Steven,
Can't speak for a jigsaw as I never owned one.
But DTs on a bandsaw are perfectly possible. However, you need a blade that leaves a fine kerf, which means one with more teeth and less set. I have used a blade meant for metal in the past (I think it was 14tpi - OK as long as the stock you are cutting is not thick (eg it works fine with 10 - 12mm drawersides).
These days I make DTs with a Woodrat or (even more recently) by hand with a Wenzloff saw and a Blue Spruce chisel, so the bandsawing of the DTs is but a memory. One trick I read about but never tried is to use a fish blade in the bandsaw. David Charlesworth, a British woodworker and author on woodworking, has often said that he uses such a blade and gets a very smooth, accurate cut with DTs.
I have never seen one but I understand a fish blade is used on a bandsaw by fishmongers to cut frozen fishies. As I understand it, it has more of a knife edge than a saw edge. But perhaps Mr C is reading (he sometimes comes to Knots) and may comment/clarify?
Any idea where I could get such a blade?
s bolton
steven,
These guys are just leading you astray. Everyone knows that you cut dovetail tails with a chainsaw! The trick is to file the teeth to the right angle so when you make the cut the bottoms are flat.
In order to do that you need a foot turned 24" grinding wheel and a jig to angle the saw to a 17.4549202 degree angle and just start the chainsaw and press down on the very top of the wheel for 22.78967 seconds whilst running the chainsaw at full throttle.
If the pins don't fit right just get a 20 lb sledge hammer and pound them in. The wood isn't as strong as the hammer and will split to form into the tails. Don't forget to provide a granite block for support!
Just goofing here.
A bandsaw works great for making the pins. You can either tilt the table to match the angle or make a shim to match the angle of the tails (which may work better). I use the tail board to align the table with the blade and stay shigh of my marks on the waste side and pair with a sharp chisel. Partially fit the pieces together and when you meet resistance, carefully just pair a bit more until they fit nice and snug.
No matter what way you choose, the best way, IMHO is to sneak up on the final fit.
Hope this helps,
Thanks. I will fire up the Jonserud.
But where can I find good blades for a bandsaw to cut dovetails?
sbolton
Here is one source for the fish blade.
http://www.sharptech.com/Content/ContentCT.asp?P=25 ------------------------------------
You can get any blade you need, I'm sure, from Suffolk Machinery. If you happen to be using a 14" band saw, their blades are especially good on them. If you call them and let them know what you're doing, they'll help you find the best blade:(800) 234-7297
Cutting dovetails with a bandsaw can yield very good results. I've seen several articles on the subject using simple jigs. A quick search should turn up something. Forget the jigsaw idea. Not nearly enough control. I tried it once . Anyway, it would be far simpler just to use a handsaw.
Paul
