I have recently decided to build a morris chair and ordered a plan. When I got the plan I noticed that to fasten the slats between the chairs arm and lower rail used dowel joints. I have heard that these joints are not that strong and loosen over time. If I decide to go with the dowel joint instead of the mortise and tenon am I setting the project up for failure?
The dowel joint is not as strong as a mortice and tenon- but in this case it would probably be sufficient- however, I would always do the mortice and tenon instead of a dowel- it is easier to make, more precise to locate, easier to assemble and makes for a stronger joint.
Bob Van Dyke
