In what situation would you ever use a down spiral router bit? An up cut or up spiral bit cleans the shavings but a down cut or down spiral bit seems counterproductive
Inlay, stringing or banding come to mind. So you don't fuzz up the cut or chip it out.
But I haven't done enough of it to say that it makes a big difference, I've used both and don't remember having an issue with either.
Downcut spiral is for handheld router situations, upcut is for table-mounted routers.
Young, poor, and eager to learn
You use a down spiral when surface finish is important and chip clearance isn't an issue (such as for shallow cuts or when inverted in a table). The up spiral is definitely superior for chip clearance and for plunge cutting but will splinter delicate material like veneered plywood.
Freud America, Inc.
