years ago I had this great drawing table, that folded up, and the top angle was adjustable. Unfortunately, I had to let it go during a move. Now I’d like to duplicate it but havn’t had any luck finding plans for one. Any suggestions?
It's pretty basic as a design, though harder to come by this table except at a flea market or antique shop.
Hinge at the front,1/4" metal rod at both ends of the back which insert thru thumblock adjusters.Often made of oak, kind of mission-style.
Thanks Jackplane, that much I remember. I was looking for a drawing or a pic, to help in the design process. The one I had, the base components were in maple, and the top was fir. Would also like to see a detail of the catch that accepts the rod. I can't remember if mine was wood or metal.
Easiest way to make them is to take a piece of brass, bore one hole slightly larger than your rod, bore two from the side to screw it to the board and bore and tap one hole from the side to secure the thumbscrew.Attached PNG drawing.Regards,Leon Jester
My drawing board is in my Den and not the shop. When I'm not using it, it is a large picture on the Den wall. When I need it, I unhook a simple hook fastner at the top of the picture. The bottom of the picture has 2 hidden hinges. I swing the picture down and rest it on 2 file caninets that are on rollers. I sit between the file cabinets with all the drawing stuff I need. When done, I swing the drawing board back up to "picture position." I have a parallel rule on the board, I like'em better than "T" Squares.
