I’m designing a drafting table and need to know the width. First I need to know which size straight edge to use, does anybody out there have any suggestions on straight edges and where to buy them?
pqken
pqken
By straightedge, do you mean T-square? or parallel rule or drafting machine?
If you are planning on using a T-Square or parallel rule, you should get it first or at least know it's length.
Tables are generally sized to accomodate a certain sheet size the sizes (in the US) are given letter designations, the sizes of which vary for architectural or engineering work. "E" sized sheets are the largest in common use. Architectural sizes are:
A= 9 x 12, B= 12 x 18, C= 18 x 24, D= 24 x 36, E= 36 x 48 (as I recall).
Engineering sizes are based on 8-1/2 x 11 size A and double as above.
A table that can accomodate a D-sized sheet is generally enough for home use.
If you try any of the websites below you should find dimensions of tables and equipment.
http://www.utrechtart.com/dsp_view_products.cfm?classID=2416&subclassID=241610
http://www.dickblick.com/categories/tables/
Good Luck!
David C
Do a search for parallel rule. This is the type that has cables attached to the table, Mayline is one manufacturer that is very common. Vinyl board cover is also good to have as a drawing surface adhered to the table. It is a smooth surface that will allow you to use a compass or trammel points to draw arcs and not ruin the surface or cause bumps or puckers.
As far as width goes, that is determined by the size of paper. I switched from 42" paper to 36" paper since that is the widest piece that I can have reproduced. My parallel rule is 48" and I use a 4 x 8 sheet of plywood covered with the vinyl board cover.
Charrette and Dick Blick are a couple of places to get drafting supplies.
J.P.
I'd invest the money in software and plotter.
All of my traditional drafting supplies are from hearlihy.com. While schools are their main market, they will send you a catalog. Everything from T-squares to vellum is there and the quality is excellent.
Nice drafting machines are available really cheap now. I bought 2 on ebay for about $60.00.
One of them was in excellent condition the other not so good. The good one included several scales.
Ron
