I just inherited 2 drawknives from my Dad, which he never used, so they’ve never been ground or honed. Last time I used a drawknife was 15 years ago and someone else had sharpened it! Any special info I should have to sharpen mine? What angle is best? I’ve checked the books I have and they all seemed to overlook drawknives in the sharpening section…Thanks!
Mike Dunbar's book, 'Restoring, Tuning, and using Classic WoodworkingTools', has an excellent section on selecting, sharpening and using draw knives.
Leonard Lee's book, The Complete Guide to Sharpening, also addresses drawknives.
DP, can you turn me on to a source for Mike Dunbar's book? thanks, DOUD
I found a copy of Dunbar's book at my local library. If you want to buy try http://www.astragalpress.com/astragal_cat_restoretuneuse.htm
Warning thou, it's easy to get carried away. This site is dedicated to woodworking.
Peter
thanks, books and reference are one expense I do not begrudge, unlike electricity and food - DOUD
Sorry to take so long to reply. Was off doing other things. You can get the book from Amazon.com or directly from Mike through his website, http://www.mikedunbar.com.
Dunbar's book, mentioned above, is recommended. A properly sharpened edge will have one beveld side and one flat side. But, unlike a chisel, the flat side should be slightly dubbed so it too has a bevel (but very small!). This helps control the tool much better than if it were perfectly flat.
Your biggest problem may be sharpening the blade because the handles get in the way. I took a piece of 2"x10" and notched one edge out to hold the sharpening stone (with a wedge). Then you can get good pressure on the blade. Some sources will tell you to hold the drawknife like a violin and move the stone over the blade, but this never worked for me. But try that too.
To use a drawknife most efficiently you also need a shavehorse, but that's for another thread.
